#1 08-03-2014 00:42:06
TeD
* Président du Club *
Lieu : Yvelines
Programmation du nombre de clignotements
Afin de mieux suivre ce fil, je crée un sujet dédié, il semble que le problème soit assez épineux pour les concessions, apparemment beaucoup n'y arrivent pas. J'attends que le mode opératoire soit republié, pour tester moi-même.
Désolé je ne traduis pas, il y a trop de posts ;-)
Sujet sur le forum US
#2 08-03-2014 00:52:11
TeD
Lieu : Yvelines
Re : Programmation du nombre de clignotements
Autre sujet avec le mode opératoire !!!
Do this, it may sound confusing and take a few times. Reread and try again if it fails.
1.) Ignition off, doors closed
2.) Hold the wiper switch in the full up position. (this is the wiper off position)
3.) While holding the wiper switch in the full up position, turn the IG on. (two presses of the start/stop switch)
4.) Hold wiper switch in the full up position for 5 seconds
5.) Move the wiper switch down one "click" or "notch", hold for 5 seconds
6.) Move the wiper switch back to the full up position, hold for 5 seconds
7.) Move the wiper switch down one "click" or "notch". hold for 5 seconds (same position as step 5)
8.) Move the wiper switch back to the rest position (neutral)
If this was done correctly, the right turn signal will flash once.
To adjust how many flashes you want, you change the intermittent wiper speed switch. P1 starts with the speed switch all the way at the bottom, P4 will be the top speed. This is found on the wiper stalk.
P1: 3 blinks
P2: 5 blinks
P3: 7 blinks
P4: Function turned off
Set the intermittent wiper speed to the desired setting.
Use the Turn Signal stalk and push down like you want to activate the left turn signal, the flashers should activate
If the turn signal blinks once, you change it to the "3 flashes" setting
If the turn signal blinks twice, you changed it to the "5 flashes" setting
If the turn signal blinks three times, you changed it to the "7 flashes" setting
If the turn signal blinks four times, you turned the function off.
Once this is done, cycle the ignition switch off, and back on, and it should be changed.
I know this is confusing. I have done it to a few customer cars, and mine. The first one took a bit to understand, and I have given you the cliff notes. The repair manual is confusing as hell.
Good luck. If there are problems I will try to walk you through it.
Read more: http://www.clublexus.com/forums/is-thir … z2vK8o5dVf
ça m'a l'air franchement compliqué comme manip, le garçon qui a conçu ce mode de paramètrage doit être super tordu dans sa tête.
#3 08-03-2014 07:46:22
Au bout de 3 4 essais on y arrive. Mais c'est surtout la dénomination des différentes positions et commodo qu'il faut comprendre. Ce n'est pas forcément plus clair en français.
Il faut juste bien vérifier que le clignotant s'allume une fois après l'étape 8 pour être sûr que le mode de programmation est bien enclenché.
Dernière modification par artur (08-03-2014 07:49:41)
#4 08-03-2014 08:16:36
Richy
Véhicule : ALFA ROMEO 1.8 T.S.
Lieu : Yvelines
Bon, ben je vais prendre un dico un premier temps
Dernière modification par Richy (08-03-2014 08:17:11)
Pour être heureux, suffit de le vouloir wink
#5 08-03-2014 11:30:14
TeD
Lieu : Yvelines
Artur, tu as écrit 3 ou 4, ou bien 34 (trente quatre)  lol
Blague à part, le concessionnaire devrait le faire et ne pas nous laisser nous débrouiller seuls. Ce n'est vraiment pas à nous de faire ça !!
#6 08-03-2014 11:45:11
TeD
Lieu : Yvelines
Traduction pour Richy  big_smile (bon même traduit, ce n'est pas QUE simple  hmm )
1.) Contact coupé, les portes fermées
2.) Maintenez le commutateur d'essuie-glace en position haute. (c'est la position essuie-glace arrétés)
3.) Tout en maintenant le commutateur d'essuie-glace en position haute, démarrez. (en appuyant deux fois sur l'interrupteur démarreur)
4). Maintenez le commutateur d'essuie-glace en position haute pendant 5 secondes
5.) Ensuite déplacez le commutateur d'essuie-glace d'un clic vers le bas, maintenez pendant 5 secondes
6.) Ramenez le commutateur d'essuie-glace à la position haute, maintenez pendant 5 secondes
7.) Ensuite déplacez le commutateur d'essuie-glace d'un clic vers le bas, maintenez pendant 5 secondes (comme à l'étape 5
8.) Amenez le commutateur d'essuie-glace à la position de repos (neutre)
Si l'opération a été réalisée correctement, le clignotant droit clignote une fois.
Ensuite pour régler le nombre de clignotements souhaités, changez le sélecteur de vitesse de balayage intermittent.
P1 correspondra au sélecteur de vitesse tout en bas, P4 correspondra au sélecteur de vitesse tout en haut.
P1: 3 clignotements
P2: 5 clignotements
P3: 7 clignotements
P4: Fonction désactivée
Réglez la vitesse d'essuie-glace intermittent correspondant au nombre de clignotements souhaité.
Poussez le levier de clignotants vers le bas comme si vous voulez activer le clignotants GAUCHE, les clignotants doivent fonctionner selon la règle suivante:
Si ils clignotent une fois, vous avez changé le réglage à "3 clignotements"
Si ils clignotent deux fois, vous avez changé le réglage à "5 clignote"
Si ils clignotent trois fois, vous avez changé le réglage à "7 clignote"
Si ils clignotent quatre fois, vous désactivé la fonction.
Une fois cela fait, couper le contact et démarrer de nouveau, le changement doit alors être effectif.
Je sais que c'est un peu confus. Je l'ai fait sur quelques voitures de clients, et les miennes. La première fois cela m'a pris un peu de temps pour comprendre.
Le manuel de réparation est source de confusion comme l'enfer.
Bonne chance.
#7 08-03-2014 13:04:40
2. Ce n'est pas la position essuie-glace arrêté. Il faut partir de la position OFF vers le haut SANS passer le cran. C'est comme quand on donne une impulsion avec les clignotants pour changer de voie, mais là on reste "en haut" sans bouger pendant les étapes 2 3 4.
5. Même chose que 2 vers le bas en partant de la position OFF, on ne passe pas le cran.
En gros étapes 2 à 8 on oscille autour de la position OFF sans changer de cran.
Dernière modification par artur (08-03-2014 13:05:18)
#8 08-03-2014 19:23:22
Tissyseb
Véhicule : IS300H Sp blanche TO+Sécu+Cuir
Lieu : Agglomération de Tours
Un grand merci monsieur le président pour cette traduction.
Essai transformé au bout de la 3 e fois. Je suis en 5 clignotements.
Si c'est pas malheureux de devoir passer par la méthode jeux vidéo (combo de touches) et qu'en concession il n'y arrive pas avec la mallette.
Ex Skoda Superb Praha 170ch DSG
Ex Skoda Octavia Praha 140ch DSG
Ex Volkswagen Polo 1.4 16S
#9 08-03-2014 20:12:36
Richy
Lieu : Yvelines
Un truc de malade, vaut mieux en rire  big_smile
Merci beaucoup Ted , j'essayerais demain  wink
Dernière modification par Richy (12-03-2014 08:42:24)
#10 08-03-2014 22:42:45
TeD
Lieu : Yvelines
Félicitations Tissysebn , il fallait oser s'attaquer à ce truc de malade comme le dit Richy. Mais qu'est-ce qui leur est donc passé dans la tête, c'était tellement simple d'autoriser ce paramétrage via l'interface multimedia!
Richy a écrit :
Un truc de malade, veut mieux en rire  big_smile
Bon courage  tongue
#11 09-03-2014 09:13:35
bougnat 63
Véhicule : RC 300 H
L'ingénieur qui nous a pondu un méthodologie pareil doit être une grand consommateur d'amphétamine  lol
Merci Ted pour ces explications je vais essayer cela dans la journée.
Prudence sur la route.
Bougnat 63
#12 09-03-2014 11:27:57
Uraya!
Véhicule : NX450h+ Fsport Executive noir
Lieu : Val de Marne
Merci Ted pour cette précieuse information.
5  clignotements pour moi aussi depuis ce matin, mais 3 tentatives quand même pour y parvenir.
Bon dimanche a tous sous le soleil smile
#13 09-03-2014 11:34:47
bougnat 63
Véhicule : RC 300 H
Modification effectuée après quelques tâtonnements (position exacte du commutateur d'E.G).
Bougnat 63
#14 09-03-2014 19:55:56
Richy
Lieu : Yvelines
Bon courage  tongue
Finalement je ferais ça demain entre 2 clients, on a passé la journée sur nos motos avec ma chéries
#15 09-03-2014 20:05:23
bougnat 63
Véhicule : RC 300 H
Richy a écrit :
Bon courage  tongue
J'espère qu'elle ne te lit pas car "chéries" avec un S, elle serait en droit de se poser des questions  lol
Effectivement c'était un week-end moto et cela à fait beaucoup de bien au moral.
Bougnat 63
#16 12-03-2014 08:13:30
Richy
Lieu : Yvelines
Oups... Labsus NON révélateur  mdr250
Bon, en attendant, ça ne fonctionne pas pour le moment l'astuce pour moi.
Je continue d'essayer.
#17 12-03-2014 08:22:58
Richy
Lieu : Yvelines
Quand tu dis démarrer, c'est complètement? C'est à dire en mettant le pied sur le frein?u juste le contact?
#18 12-03-2014 08:30:17
Richy
Lieu : Yvelines
Bon, j'ai essayé des 2 façons, ça marche pas non plus, doit y avoir un truc que je fais mal
Dernière modification par Richy (12-03-2014 08:30:32)
#19 12-03-2014 08:45:58
Richy
Lieu : Yvelines
Bon courage  tongue
Bon, ben là ça me fait moins rire, voir ça commence sérieusement à m'agacer  mad
Effectivement, ça aurait été tellement plus simple de le paramétrer à l'atelier, voir même dans l'ordinateur de bord de la voiture
#20 12-03-2014 09:43:55
Mets le contact, assures toi que les essuie-glaces sont arrêtés, coupe le mode automatique.
Coupes le contact.
Pousses le comutateur des essuie-glaces légèrement vers le haut sans passer de cran et tu maintiens dans cette position.
Démarres la voiture.
Au bout de 5 secondes tu lâches le commutateur d'EG pour le pousser aussitôt légèrement vers le bas et tu restes dans cette position pendant 5 secondes sans relâcher.
Tu lâches le commutateur d'EG pour le pousser aussitôt légèrement vers le haut et tu restes dans cette position pendant 5 secondes sans relâcher.
Tu lâches le commutateur d'EG pour le pousser aussitôt légèrement vers le bas et tu restes dans cette position pendant 5 secondes sans relâcher.
Tu lâches tout et normalement le clignotant s'allume une fois. Si là c'est ok tu poursuis.
Je me suis trompé la bonne procédure est un peu plus bas !!!
Dernière modification par artur (12-03-2014 13:57:02)
#21 12-03-2014 10:04:24
Richy
Lieu : Yvelines
J'ai l'impression que c'est bien ce que je fais, mais bon, sûrement que non.
M'en vais recommencer  hmm
#22 12-03-2014 10:20:43
Richy
Lieu : Yvelines
mad Blasting_anim 2gunsfiring_v1 mgwhore foire foire foire frown indecis
#23 12-03-2014 10:31:44
Richy
Lieu : Yvelines
Ça me saoul, j'abandonne
#24 12-03-2014 10:43:14
Pourquoi tu ne vas pas dans une concession ? Cette procédure est à usage interne Lexus, c'est à eux de faire la reprogrammation normalement.
#25 12-03-2014 11:09:17
Richy
Lieu : Yvelines
Ouais, j'y ai pensé, mais pas certain qu'ils soient au courant. En tous cas pas chez TOYOTA où je vais.
Non mais j'aimerais comprendre où JE merde, y pas de raison. J'ai eu 3 TOYOTA, et j'arrivais à faire des manips cachées, mais là...
