En attendant pour les possesseurs d'IS new gen, voila la manip pour pouvoir regarder des DVD en roulant, accéder à la composition téléphone, à la liste des MP3, options normalement grisées/indisponibles pendant qu'on roule. Marche aussi bien avec le système Mark Levinson (ML) que sans.
Duration: 30 minutes
1.)Remove the sliver pieces to the right and left of the wood trim on either side ot the shifter....they are simply held in with clips, they come out up/back diagonally
2.) Re move the shift knob by turning it counterclockwise.
3.)Remove the shifter plate assembly by opening the ashtray door and pull up with your fingers (i slid the armrest back) it is also held in with simple clips.
4.)Remove ashtray assy (two phillips screws)
5.)If you look in the top of the air vents you will see four 1/4" holes in the two vents. If you gently insert a flat head scewdriver at about a 45 degree angle up into the holes and gently pry down you will see that a plastic clip will come down with the driver and clip into a down position....do this to all four...then with a "plastic" pry tool, pry the vents out ...the dash is very forgiving....it will not dent...(at least mine did not) and pull the vents out again they are held in with astandard clips....This was the hard part
6.)Remove the Nav unit . There are 4 10mm bols holding in the complete NAV assy....remove them and you are set
7.)Cut the PINK wire located on connector J50 and the WHITE (with silver paint) wire on connector P1.
After cutting the Pink and White wires, you put a cap on the wires comming from the Navigation unit. You then connect the Pink (wireloom side) and White (wireloom side) wires together.
*** Note if you have ML and want it to play DVD when moving. You will need to GROUND the parking break wire also. It's the <span style="color: #Red;">RED</span> wire on the J50 connector.
Hey,
Je ne sais pas comment ca se passe sur les nouvelles IS mais sur les anciennes il y avait aussi un truc pour gérer le DVD en roulant mais il ne fallait pas le faire de manière définitive sous peine de problème avec l'ECU et l'odomètre.
Ciao Lexus ...
moi j'ai un interrupteur pour le GPS.
mais de toute façon, ca se re-vérouille dés qu'on change de borne GPS
ex Lexus RX 450h F-Sport 2013
Quelqu'un a des infos pour les nouvelles IS, concernant le GPS et le DVD?
J'avoue que j'aimerais pouvoir mettre un dvd en roulant pour que le gamin derrière me lâche les bask.
Sinon tant pis, je vais devoir acheter un lecteur dvd portable.
Et bien, c'est écrit par Frank, tu suis les étapes! Je ne connais pas la nouvelle IS.
Yes, mais est-ce que Franck a effectuer cette manip' ?
Oui c'est bien pour la nouvelle IS la manip ! Testé et approuvé par des dizaines d'américains. Moi je ne l'ai pas fait car pas envie de perdre la garantie sur ces équipements et que je n'utilise pas le DVD ou si peu. On a le son tout de même en roulant et ça me suffit pour écouter des concerts par exemple.
En tout état de cause, je pense finalement que je vais plutôt investir dans un lecteur dvd portable pour le mioche derrière.
Car après tout tu as raison, pas la peine de perdre la garantie sur ces équipements pour ça.
Merci Franck
Gamin....Mioche... tu y vas un peu fort avec ton fiston, Joker
ah bon?
Il n'est pas à plaindre! Il est pressé de prendre ma place au le bougre.
Ne t'en fais pas pour lui!!! on l'
Tu as fait comme dans la pub pour la nouvelle astra?
Tiens ta nouvelle voiture! en attendant, c'est papa qui en profite...
Tout à fait
Papa en prend soin.
bonsoir,
je suppose que toutes les is avec multimédia ont la système mark levinson ( ML ) an france, donc il faut aussi s'occuper de ce 3ème fil rouge , ma question est donc , après avoir reliés les fils blancs et rose, on en fait quoi en clair de ce fil rouge ?
merci
Lexus is 220d novembre 2006 exectutive pearl white boite courte
De mémoire il faut le connecter à la masse ; as-tu connaissance du kit de Toine45 qui permet d'obtenir la même fonction mais d'autres également ? (voir ici : http://forum.clublexis.com/viewtopic.php?id=12945)
bonjour,
et merci papy, toujours très actif sur le forum je vois !
oui j'ai vu son kit, mais je viens d'acheter la mise à jour E13 de 2010/2011 , là je ne veux que le dvd en roulant en plus pour les passagers , ça fait un peu cher juste pour ça, et je suis prêt à couper les fils vu que ma voiture n'est plus sous garantie... d'ailleurs je revends la mise à jour E13 europe de l'ouest si ça intéresse des gens ? 65 euros port compris
la mise à la masse je comprend ce que ça veut dire mais je ne voudrais pas faire de bêtise, donc en clair le mieux c'est de le mettre ou le fil et comment ? soudure ?
merci
Le plus simple est de sertir (à la main avec une pince) une cosse ronde avec un trou central de 6, 8 ou 10 mm et de la serrer sous une vis existante de la carrosserie.
Dernière modification par Papy Mougeot (09-02-2011 18:31:30)
ok , merci beaucoup, voilà des bonnes explications pour les nuls comme moi
bonne soirée
bonjour,
D'ailleurs je revends la mise à jour E13 europe de l'ouest si ça intéresse des gens ? 65 euros port compris
Ça couvre quel secteur Europe de l'ouest, et E13 est-ce une des dernières versions?
France, Netherlands, Belgium, Luxemburg, Portugal, Spain, Ireland, Britain, Canary Islands, Andorra, Monaco, Switzerland, Liechtenstein, Italy, San Marino and Vatican City and Mainstreets of Germany, Scandinavia and Austria
la version E13 est la dernière sortie, 2010/2011
Peut-on passer à la version E13 directement si l'on possède comme moi, la version 2007 ? Est ce compatible ?
Si oui, considères que ta version E13 en vente est vendue.;)
Salutations.
LAURENT
EX IS 200 1CO PACK LUXE DECEMBRE 2004
EX IS 220D pack sport décembre 2007/vitres surteintées/ 72000 kms
GS 300 gen3 executive avec TO - vitres carbone medium - 07/2005 - filtre K&N - echappements INOX CESAM - 100000 kms
Tout à fait Laurent !
Osaka, je suppose qu'il s'agit de la version complète avec les 4 DVD (?).
Dernière modification par Papy Mougeot (10-02-2011 16:59:28)
Non a priori il ne vend que l'europe de l'ouest mais d'ailleurs, est ce que ce seul DVD permet de mettre à jour le GPS ?
LAURENT
Oui, n'importe lequel des DVD met le firmware à jour ; tu as raison, j'ai vérifié que la description des zones géographiques correspond uniquement au DVD "Europe de l'Ouest". Pour l'Allemagne, seules les grandes lignes figurent mais pas le détail.
Merci Papy pour tous ces renseignements donc j'ai confirmé par MP mon achat car pour l'Allemagne, ce n'est pas très grave pour mes voyages qui se passent plutôt dans le sud de l'Europe (Portugal et Espagne).
Salutations.
LAURENT
