#1 24-09-2008 20:52:10
Infectomilo
Roi du macadam
Codage moteurs
Les moteurs de nos lexus (toyota) ont des codages bien particuliers, j'ai trouvé ce petit lien qui explique les différents codes. Je me  suis permis de couper un peu la liste exaustive des moteurs 4 cylindres pour ne garder que les 6 en lignes essences, V6 et V8 essence et accessoirement 4 pate diesel tongue
http://en.wikipedia.org/wiki/List_of_Toyota_engines
Toyota Motor Corporation has produced a wide variety of automobile engines. The company follows a simple naming system for their modern engines:
The first numeric characters specify the engine block's generation
The next one or two letters specify the engine family
The suffix (separated by a dash) specifies the features of the engine:
Suffix Feature
A Valvematic variable lift intake head
B Twin SU-style side-draft carburetors
C Carburated / California Emissions Controlled
D Twin Downdraft carburetors
E Electronic Fuel injection
F Economy narrow-angle valve DOHC
G Performance wide-angle valve DOHC
H High compression like 9.8:1 (example: 5E-FHE)
High pressure charged (example: 2L-THE)
I Single-point fuel injection
J Autochoke (Early models) or unknown pollution control
L Transverse
M Philippines' market (meaning unknown)
N CNG fuel
P LPG fuel
R Low Compression (For 87 and below octane fuel)
S Swirl intake (1980s)
SE Direct injection (1990s)
T Turbocharged
U With Catalytic converter Japan-spec emissions
V Common Rail Diesel Injection (D-4D)
X Atkinson cycle (typically also indicates a Hybrid engine, as Toyota only uses the Atkinson cycle with hybrids)
Z Supercharged
For Example
4A-GE
4 - 4th Generation Engine In The A Engine Family
A - The Engine Family it is in
G - Wide-angle dual camshaft
E - Electronically Fuel Injected
22R-TEC
22 - 22nd Generation Engine In The R Engine Family
R - The Engine Family it is in
T - Turbocharged
C - California Emission Controlled
[edit] Straight-6
1979 - 2.0 L (1988 cc) 1G             le moteur de l'IS 200 serait de conception si ancienne????? hmm
1993 - FZ - DOHC
1993- 4.5 L (4477 cc) 1FZ
1990 - JZ - DOHC
1990 - 2.5 L (2491 cc) 1JZ
1993 - 3.0 L (2997 cc) 2JZ            le célèbre! ___
[edit] V6
2006 - 3.5 L (3456 cc) 2GR                Les moteurs actuels de la Gen2
2003 - 3.0 L (2994 cc) 3GR
2006 - 2.5 L (2499 cc) 4GR
[edit] V8
2006 - UR - DOHC/VVT-i
2006 - 4.6 L (4608 cc) 1UR
2007 - 5.0 L (4969 cc) 2UR                moteur de l'ISF
2007 - 5.7 L (5663 cc) 3UR
[edit] Diesel
[edit] Straight-4
2001- 3.0 L (2982 cc) 1KD-FTV
2005 - AD - DOHC
2005- 2.2 L (2231 cc) 2AD-FTV
2005- 2.2 L (2231 cc) 2AD-FHV                  moteur de la 220d
2006- 2.0 L (1998 cc) 1AD-FTV
#2 24-09-2008 21:12:36
SEB
* Trésorier du Club *
Re: Codage moteurs
Sympa cette trouvaille wink
#3 24-09-2008 23:38:04
ravrouva
Re: Codage moteurs
Excellent résumé, Infectomilo..:smilejap:
PS: IS-F --> 2UR-GSE
Today Tomorrow Japan..
[ Généré en 0.006 secondes, 9 requêtes exécutées - Utilisation de la mémoire: 521.73 KiO (Pic : 522.77 KiO) ]
